Re: Features
#49Yes my provider have archive.
So to see what is passed i need to go to TV Guide and choose what i want to see?
Re: Features
#51xtream-code API:
After replacing the username, password with a simple user line and the stream with the Stream ID , you will get a TV Archive from 16:00 pm 2016-03-19 and with the duration of 120 Minutes ( 2 Hours )
Prog what you can do?
http://ip:port/streaming/timeshift.php?username=X&password=X&stream=X&start=2016-03-19:16-00&duration=120
Re: Features
#53Thanks prog but when i go to tv sources i only have kartina tv, sovok tv, auto search iptv, dvb over iptv, sat iptv.
I cant see xtream in tv sources.
Edit:
I've checked Beta version and i see xtream in tv sources. All works fine channels are imported and the channel with timeshift function have a clock logo but when i push the timeshift back i get "Server error".
Also if you want send me the file for i can translate what you recently added to portuguese.
Thanks
Edit:
Thanks
Re: Features
#55Prog check your pm's for logs link.
Note: When i click in login in xtream he always show: Connecting... but never connects.
User, password and server are ok cause i get channels list and epg so i dont know why timeshift is not working too...
