AC3 Codec?
#1Hey, im using a android m8s ii mini but i need support for AC3. Anyone know how to install the codec or solution for this??
Yeah i tried it but looks like its not working. How do i enable passthtrough in android? I cant find the option, only in KODI. By the way. Is it possible to add "Software" Decoder? Then you can get it to work but not the best soultion....Prog wrote:One user from google play was wrote "AC3 FIX=Install codecs ffmpeg_v7_neon or whatever for your system & search here for ac3 & install apps + ENABLE HDMI PASSTHROUGH IN ANDROID SETTINGS"
I tried disabled it but it didnt work...Prog wrote:You can try with disabled engine at first.
