Re: ProgTV IPTV New option
Prog wrote:Yes, I plan this in near updates.
Thanks for ur help i see that u add it but it's not working as long as we add the user-agentand save by ok and ok then check the channels nothing working plus if we exit the app and oprn it again the user-agent field is empty
Thnks bro
Now the problem of user-agent field became empty if we exit the soft is solved but it's not working progtv keep sending his default user-agent in the place of my user-agent
For example my user-agent is Lavf/57.25.100 but ProgTV sending his User-Agent: VLC/2.1.3 LibVLC/2.1.3
Anywhere we are in progress will still in touch with you bro until completely fix
good luck
