Other new features
Hello Dear Prog thanks for the support and ur time to fix the user-agent in the other post noe i have something new to ask about it
* swapping dow or up to chenge screen brightness
* Background playing
* Option move in channels list to sort the channels as we like
* Possibility to play our media (videos,song) direct inside progTV
GOOD LUCK
Re: Other new features
Prog wrote:1. What you mean?
2. Options->Controls->Background ....?
3. Sort and some other function in menu of channel list.
4. Many other app best for files. My aim is best TV.
Is that didn't see it
But sorting mybe you didn't get my idea is to sort as we like one channel up one down not sort by name or by date i mean manually sort i hope u get it
Plus swap up to down to change screen brightness
