Can we add .w3u lists on this apk?
Or from pastebin of type https://pastebin.com/??????????? and .w3u?
Thanks.
Re: .w3u list
#3The link was an example. It was not real, here are many and the explanation http://thegeekhammer.com/wiseplay-lista ... tualizadas
Re: .w3u list
#6Any progress for this?
The links are from the wiseplay program.
https://www.meindroid.net/listas-wisepl ... ulio-2017/
Does ProgTv support lists from pastebin?
http://pastebin.com/raw/J7JPWQcq
Re: .w3u list
#7I am remember about that thread but like prepare stable version at first. too many changes in HLS and some other parts.
Re: .w3u list
#9Hello, I saw the implementation with this channel source for days.
But as I comment by email most of the channels do not work in progtv and yes they work in the specific program for this list of channels.
I added in an email many days ago a link for channel list. You can try there. In the channels, the poster waits for long time and error. In the specific application they work without problems.
Some channel of the same list that is acestream works as follows.
On opening it leaves the application and automatically starts acestream. Come back or I do it and the charge begins. Maybe you see 1 second and stop the image, it does not continue. If I try again to enter the channel does not do the same, you do not see anything. If I close progtv and re-enter it does the same.
Re: .w3u list
#10And so.
1. Is it list correct? All channels from file in list of ProgTV?
2. You can post "bad" links to other thread and I try they. Of course ProgTV not support all formats in world. That is impossible.
Re: .w3u list
#11Some more update of w3u support in last BETA version http://www.progdvb.com/progtva_download.html
Re: .w3u list
#14"embed" ? IsHost field in w3u?
I don´t understand
List *.w3u, many channels do not work in 2.44.3 beta but in wiseplay yes
I don´t understand
Re: .w3u list
#15What channels for example? embed and IsHost is flags in w3u and I am not have idea about they.
