Hello
Not seeing but is it possible to go back to the last channel using an android remote. Using on a Tv box.
Thank you in advance.
Re: Is it possible to go back to last channel
#3Thank you for replying.
I am thinking one will have to be assigned, on stb emu you can use the delete button in full screen mode and perfect player uses the left button in full screen. These are the only two that have that feature I believe.
So maybe you can assign a button for it, this would really be great, hope it can be done.
Sorry for the other ask but notice some of the channels have a small screen, I see where I can change the zoom but is there a way it can be set for all channels?
Thank you again.
Thank you again.
#4You can setup "last channel" in Options->Controls->Bind.
I think you mean letterbox. Try in channel list properties.
#5Tried a number of keys it did not work.
Not sure as it is because of a remote. I hear a noise when I click the key but it does not go back to the last channel.
#6Hi friends.
You can setup last chanels only but we hope that you add ability to recall last 5 or 10 chanels list visited by baring the function to remote controll keys in controll option.
#7Have remote control ticked and touch and mouse unticked and it still is not using the key I assigned. I can change other keys and it works but not for last channel.
Hoping for help on this, maybe doing something wrong.
Thank you
Thank you
#9Sorry did not know I had to have history on, I had it turned off because I did not want to have a lot of files but guess needed. Wouldn't this bloat the software?
Thanks for the reply.
