Hello! I will be using three individual Android TV boxes and would like to know if I can copy the configuration settings from one to the other two. This would save time getting them identically setup.
Is this an option?
Thank you!
Re: ProgTV for Android
#4I just Install this app through Play store on my Wetek Play2, I want to play a chnnel running on my other Enigma2 box in Home, Both on same network, Is there any guide, how to do this, Without creating a m3u files, any direct method ?
#6I want to use it as client, what setting to sever is required to work with ProgTVA ?
