hi i use this nice ProgTV android iptv one problem is that some times i change channel and than tv loads and there is video but no sound
so when the change player in playback to ffmpeg i hear sound but video go in slow motion is there way to fix this ??
and is there new android version comming thank u for your time
Re: FFmpeg player No sound
#3ac3 i think looks like ac3 thats what it sayed but the sound is normal but video is slow motion can that by sound problem ??
on the ffmpeg option
#4becouse last fiew days 2 channels when the program change on the tv iptv the format change as well and it shows ac3 but video format it wont show but when i change to ffmpeg sound works fine and video go so slow motion am like why my video go slow motion when sound is fine
#6ok but can u maby add difrint media player to the progtv like vlc or mx player difrint player that plays the ac3 file fine and normal with out slow mosion the video
becouse subtv have there own app and video plays fine some times with out sound as well so i think its the ac3 but subtv dont have record option that record my show if i mis it progtv is best i seen on internet but maby it needs new video player in it ??
#7External player not support 2/3 functions of ProgDVB. But possible ac3 codecs from device.
btw, what version of MX support ac3? Simple version from google play?
#8https://www.guidingtech.com/37749/mx-player-no-audio/ you need follow the video but it works for mx player but there more players than only mx specaily vlc is nice one
even https://apkpure.com/3gp-mp4-ac3-hd-vide ... idplayerxx is nice one
or https://play.google.com/store/apps/deta ... ideoplayer
there so mutch can u add more players in the progtv?? woth by so awsome
#10I am not sure about use external player. Do you really need this way without timeshift, record,.... ?
#11Its easy becouse when i am not home and i dont want mis my show your cool progtv let me record my show so i can watch it later back but when i watch show on. Ffmepg and video go slow motion than am like can it by. Fixed and maby more video players add to progtv or addon helps with extra players
#12Kodi haves userdata file option for external players can u do same for progtv
http://kodi.wiki/view/HOW-TO:Use_extern ... on_Android
#13Problem not in xml. Problem in functions. For example no record and question about remote control with external player.
