hi all,
I use prog tv on android, box : zidoo h6 pro.
But I have a problem.
When I use the progtv decoder : my channels are accelerated ...
If I disable the internal decoder and I use mx pro channels are normal ??
I do not understand.
Thx for help
Re: Accelerate channel ?????
#2What is "my channels are accelerated ..."? Some text message? Send me screen
#3re,
Once on my channel, my image is accelerated.
the show or movie is not at normal speed but accelerated
I dont understand
I dont understand
#5playback mode ??
Where is it, please ?? its when i m on a channel or in options ??
A screenshot may be ^^
Thx for first reply
Thx for first reply
#7re,
Sorry but i dont undestand, i m french and very poor English....
#8Re,
I found the options for video.
When i choose mediaplayer+ my movie is ok.
Whats is the best : mediaplayer, open max, ffmpeg, media player + ???? And difference between this 4 options
Thx for reply
Thx for reply
