Hey,
I installed ProgTV in my father's MiBox.
I usually leave for him the box running 24/7 + progtv, without shutting down.
And he just turns on the TV.
Wifi always works, not disconnected.
ProgTV is the most convenient for him, and works best! But there is one bug I found.
When he turns on the TV again, the channels refuse to loading
What helps is to restart progtv, and then the channels are loaded again.
Do you know about this problem? Is there a way to fix it?
I tried with other players and everything is fine, so I think it's a bug maybe in the current version
Re: Bug channels not loading after screen on (MiBox)
#3I just turned on the TV and again it happened,
"Waiting too long... No signal." every channel
ProgTV Logs:
https://drive.google.com/open?id=13XNmi ... hlkYfJC4TK
ProgTV Logs:
#5No dns name for mym3u.ddns.net... Can you give one link for test? Or ask provider about test login for me.
#6This is IPTV service that stick to 1 IP of the client,
We have to be on the same IP for it to work for you.
Like: we both connect to HideMyAss VPN US (same ip)
and you can watch also.
These are the links that works on every IP:
http://keshethlslive-lh.akamaihd.net/i/ ... _1400.m3u8
http://mym3u.ddns.net/keshet
http://mym3u.ddns.net/reshet
#7First link is working, second return 403. Do you check with different user agents?
#8It works, probably they blocked it (GEO) , so should use VPN from Israel.
I'll be able to give you my HMA (HideMyAss VPN) key
But I do not want to bother you to much with my problem either^^
