Same channel name - different links (merged)
I found some constellations that will not work correctly when you have 1 channel name several times with different links (of which some are bad links) merged.
Example that is ok (the good link is played automatically):
Channel #1 BAD Link
Channel #2 BAD Link
Channel #3 Link OK
Channel #4 BAD Link
Example that is NOT ok:
Channel #1 BAD Link
Channel #2 Link OK
Channel #3 BAD Link
Channel #4 BAD Link
Another example that is NOT ok:
Channel #1 BAD Link
Channel #2 Link OK
Can you please test this?
Thank you!
Re: Same channel name - different links (merged)
Please test this m3u. Does it work merging the channels?
The index2500.m3u8 link is the good one.
Thank you!
#EXTM3U
#EXTINF:-1,RT_Not_OK1
https://secure-streams.akamaized.net/rt/BAD1.m3u8
https://secure-streams.akamaized.net/rt/index2500.m3u8
#EXTINF:-1,RT_Not_OK2
https://secure-streams.akamaized.net/rt/BAD2.m3u8
https://secure-streams.akamaized.net/rt/BAD3.m3u8
