Crashing in Fire Tv
Hello
Seems to be crashing in Fire Tv with latest 2.50.7. It seems to be an issue with the h.264 video, Ffmeg may be the problem.
Also the channels numbers for the remote can only be used with the virtual keyboard which brings the fire tv pop up, cannot use with RC keyboard numbers input as back to front.
Thank you
Re: Crashing in Fire Tv
Sent you a PM with files, hope you got the zip file.
On the remote issue, the only one that works for FireTv is the virtual one but it pops up the FireTv input box
The other options input the channel numbers like this:
123 is showing as 321, you have to move the cursor on the 1 to the end so you can get 123
Thanks for the help.
