while using iptv client on progtv ...everything is fine...except if you remain in one channel...for about 20 min or more the massage came error timeout with red....and you should click try again to refresh the channel....
as long as your changing the channel you will not face this kind of message...but...when you keep on channel...after like half hr ..the channel stop and came that message...
BTW...this issue i dont have it in other iptv apps...
Re: The new version still have time out error !!
#3not the same error ...but the same thingProg wrote:Is it same error?
http://test.progdvb.com/89/progtv.beta.2.26.5.apk
this version dont show any kind of message ...just after a while on a channel...about the 20 to 30 min ...the channel stop and you should change the channel and back again to it to continue ...
- that before showing timeout error message with try again button
-this version doesn't show any kind of message ...just freezing channel and need to change and return to let it continue or working again
#4Is it depended from channel? Can you share me link for test?
#5No...not from the channel ...i already told you in the first post that i ve tested other app ...for example ( perfect player) and the channle didnt stop after while...Prog wrote:Is it depended from channel? Can you share me link for test?
#6timeout mean server terminate connection. And I must test with this(!) server.
Also please send me logs.
#7I am having the same player, I changed the timeshift to save to internal memory instead of ram and upped it to 800mb and now I can watch for about 1hr before it freezes
#8Hm. Is it timeout error depended from timeshift size?
