7.17.06
hi, i use a quad-tuner dvb-t2 card (for italian digital television).
every time you made a new release, you make new disasters.
this time happen this:
i open different channels with all tuners.
with this relese (7.17.06) i have some channels
in 1 tuner that don't work.
when i succesfully make the channel on,
channels on another turn stop to work and they disappear.
when i make on them, the channels on the other tuner
disappear again.
it's like that 1 of 4 tuners must don't work.
why this ???
don't tell me to search channels again,
because it's impossible that they disappear inside 1 day
every day.
thank very much.
Re: 7.17.06
Do you have multi-tuner DVB-T device? Chech multi tuner options in ProgDVB (dual tuner must enabled) and try scan again.
ps: But problem is possible. I was change some code in DVB-T.
Re: 7.17.06
hi, the problem is this:
if i turn on the program and i open fast channels
on all tuners, they work fine.
if i turn on the program and i open some channels
and nothing more, when i try to open other channels
some of them don't work anymore (1 tuner).
if i make them to open, another tuner stop to work.
another problem:
after, when i want turn off the program, this don't turn
off fast, but i have a blue-circle that rotating.
i have to use task-manager for close your program.
thank.
Re: 7.17.06
hi, i use quad tuners and i open at least 10 channels.
sometimes, inside the day, 1 tuner stop to work and
i lose many records.
if i try, and sometimes i make tuner to work again (with channel-property, refresh),
everytime you made a new release, i have always
1 or more problems.
can you make that 4 tuners work all day without they turn off
if i don't want do ?
thank.
another question:
i use scheduler for my records.
what to touch inside a channel, that
when has finish to record i want it stay
still on ???
thank.
Re: 7.17.06
1. previous version is better? What mode in Options>device name? ProgDVB not stop tuners. Only select free tuner for current operation.
2. Not clear. Channel not closed after record?
