Windows 10 Creators: I need record a TV program so I open ProgDVB I insert start time recording and end time recording, I minimize the winodow of ProgDVB, I lock my account so I can leave the PC safety and program stop to work.
Seems I AM able to record a program only IF I leave my account logged so PC is vulnerable... IF I need record a program I need record because I AM away of the PC.
I hope in the future will be possibile to minimize the program, lock the account and have the recording working.
Re: Issue: when windows is locked programmed recording not w
#3Can I ask what you mean? Steps?
Thank you.
Thank you.
#5Thanks tested,Prog wrote:Options - video - codecs - renderer
the issue is the same.
I open the program, I schedule a record, I lock Windows account... than sometimes records or TV stop to work.
If I need use the PC and I unlock the account the program always stop to work and I need close and open again.
Is not much stable..
.. hope you can test and fix, improve in the future.
Thanks
#6I continue to see this issue mentioned in this topic.
Windows 10 Pro Creators,
PROGDVB 7.19.09
I tried to select different video codec but issue is the same:
I schedule a recorder of a program than I reduce the program to try icon, I lock windows.
When I unlock Windows the program stop to work so if the recording is in progress is lost.
I have to close the program and open again.
Are you able to reproduce?
PROGDVB 7.19.09
