When I look at Channel X, switch to Channel Y, and then switch back to Channel X it doesn't start.
It says invalid password.
If I wait 15-30 seconds before I switch back Channel X works.
The issues is not with the iptv-provider as the issue doesn't happen with other applications with the same m3u-file.
Is it some kind of caschin-setting I can change to fix this, is it a bug, is it something else I can change in the settings to fix this?
Re: Switching back fast to a channel previously watched doesn't work
#2May be this some kind of protection of server? In most case server allow only one channel at once.
#3It's not the server, as mentioned in the first post it works fine in other apps (vlc and kodi) towards the same server.
#4This is not reason for ProgTV. Can you give me access to this server?
