ProgDVB, *.flv to be links Restarting after crash.
Example links ; choise "Free WorlTV"
_http://85.113.29.234/live/4002.flv|Muzika
_http://85.113.29.234/live/5001.flv|KTRK
_http://85.113.29.234/live/7001.flv|KTRK Sport
_http://85.113.29.234/live/6001.flv|Ala Too 24
These links, with VLC normal.
And also; do have any other links for these channels ?
Re: ProgDVB "Restarting after crash"
#3Program DATA/ProgDVB/Logs/ Inside ExceptionReport.txt file ;
time: 6.12.2017 14:24:52
Type: Crash in unmanaged part
Module: C:\Windows\SYSTEM32\msmpeg2vdec.dll
Thread: 0x4ac
Thread: 0x4ac
#5This is crash in video codec. try use other codec for example LAV.
#6With Lav Filters crach.
With FFDShow filter, there is only picture. So, no video.
Well, you can try this example link ;
Ala Too 24 ;
With VLC and Acestream, there is normal video.
Ala Too 24 ;
#7Please remember me about FLV after 2 weeks. I have idea about that.
#8You can try last prerelease. This is very first version and possible not stable.
#9I try Pro 7.21.06 and Pro 7.21.06g
and
I try with Lav Filters, FFDShow Filter and Elecard Filter.
Same Problems;
1. It opens very late. 30 to 40 seconds ...
2. There are breaks in the stream.
3. Restarting after crash, continue.
and
Same Problems;
#11H version work.
Current disruptions;
* "Preparing" time is very long. ( 30 - 40 seconds )
* "Connection" a little longer too.
crash no !
crash no !
#13This time *.flv links are complete. ( With "i" version )
Thank you so much...
#14Now is, problem rtmp( *.stream ) links.
Example link ;
rtmp://91.205.49.83:1935/live/live.stream
* "Preparing" time is very long. ( 20 - 30 seconds )
At "rtmp" link channel change; to be "Restarting after crash"
* If the channel is closed while in the rtmp( *.stream ) link, progDVB starts itself.
Example link ;
