Hi im in turkey and cannot look uefa championsleague oder euro league matches on TRTSpor or TRT1 (Türksat) when the matches airing the chanel is locked!?
I'm in turkey, what is the problem? My System is operating in German, i have changed the region from OS to Turkey but not solved the problem.
EPG is also not shown on Türksat also not up-to-date on Astra (German Channels), the update function for EPG is also not working.
Re: UEFA Matches Region Locked?
#3TürkSat 3A/4A | 42° or what are you meaning by source?
TRTSpor & TRT1
TRTSpor & TRT1
#4Ops. Yes, channel can be locked on some hours. Look indicator in ProgDVB.
Check epg update in last version.
#5EPG is now ok but what is with the locked UEFA Matches?
Why it is locked it shoudn't be locked?
İf i was watching from another country, it is normal that the signal is locked, but not in the country of the channel?
Ok i can go to the next room and look over tv, but that is not the solution of the problem.
