7.23.9 issues
hello i am up to date and running 7.23.9 i have noticed some issues . lagging slow response when clicking on a channel or using the search feature.
also if you can add better mpeg 2 codec. on other versions sometimes certain channels have worked and now they dont. thanks. app has shut down a few times also.
Re: 7.23.9 issues
gio3535 wrote:
Fri Jun 01, 2018 3:37 pm
How is your computer equipment old or new?
Could your computer equipment be poor?
Yes, that's a problem Prog demultiplexer (mpeg 2 codec).
Make a change to Codecs Audio Typ: System good. Not Prog Audio Renderer.
Re: 7.23.9 issues
Card USB DVB-T TechniSat AirStar TeleStick 2.
What issue Prog Audio Renderes buffer hangs...
Try to change the Codecs Audio (System) hm works ok!
But still the problem is the subtitles hang... or the channels (scanner) read nothing updated.
Codecs Audio System, DirectSound... works is ok.
(Buffer) Bufora and PIP good works is OK.
ProgDVB codecs AAC add New Elecard AAC Audio Decoder?
@Prog
Please repair it (bug Fix, Add)
-Channels and EPG I am looking for a channel that will not read this (Scanner PID and network).
-Codecs Prog demultiplekser and Prog Audio Renderer by buffer hang...
-Codecs New Elecard demultiplekser v1.4 the issue of subtitles all the time text.
-Codecs New Elecard AAC Audio Decoder Please add ProgDVB codecs AAC?
