Hi, it was fine for a long time now today it crashes on startup and repeats. Cannot do anything.
Type: Crash in unmanaged part
Module: C:\Windows\system32\dxva2.dll
Thread: 0x2418
Re: Creash repeatedly on startup
#2Do you have message box when start PROGDVB after crash?
In any case you can uninstall PROGDVB and install again
#3Not sure why I would need to uninstall and reinstall lose all my settings when it has been working just fine for a very long time. It work after a reboot but if I close the app and come back to it later ti will not run. And really just showing some minimal error and restarting in an endless loop is useless. Put some proper try catch statements in and show the real error.
#4Type: Crash in unmanaged part
Thread: 0x9ac
18:59:17.745 - !! TopLevelExceptionFilter !! ACCESS_VIOLATION/Continuable
18:59:17.746 - module: C:\Windows\system32\dxva2.dll
18:59:17.746 - thread: 0x9ac
18:59:17.748 - !! TopLevelExceptionFilter !! ACCESS_VIOLATION/Continuable
18:59:17.748 - module: C:\Windows\system32\dxva2.dll
18:59:17.748 - thread: 0x9ac
18:59:17.750 - !! TopLevelExceptionFilter !! ACCESS_VIOLATION/Continuable
18:59:17.751 - module: C:\Windows\system32\dxva2.dll
18:59:17.751 - thread: 0x9ac
18:59:17.753 - !! TopLevelExceptionFilter !! ACCESS_VIOLATION/Continuable
18:59:17.753 - module: C:\Windows\system32\dxva2.dll
18:59:17.753 - thread: 0x9ac
18:59:17.755 - !! TopLevelExceptionFilter !! ACCESS_VIOLATION/Continuable
18:59:17.755 - module: C:\Windows\system32\dxva2.dll
Can you explain these errors please?
Thread: 0x9ac
#5Rebooted yet again and it works now. But I know it will not last. Something is stuck after closing the program that never recovers.
#6Dxva2.dll mean some problem with hard acceleration of video codec.
#7Ok but then why it works for hours and hours after a reboot but if I close the app and come back in a few then it crashes?
#8Possible so bugs or memory leaks collected on driver or video codec level. You can try use other codec
#9How can I change codec by editing an ini file? I cannot get into the interface while it keeps restarting
#10Progdvb.ini
You can find and remove lastchannelid... for start Progdvb without start of channel.
#14I have tried every codec and none fix the issue. It crashes every time. No longer usable at all.
