Sat (Satellite) TV
Where TV is not visible need to have a sat decoder on the TV.
ProgDVB can work on the PC as decoder for see channel by using Sat TV on the PC?
Need to find a sat cable for PC and than ? How to configure ProgDBR for made list channel from Sat?
Thank you for the help.
Re: Sat (Satellite) TV
Hi, i want see TV on the PC. The TV works with sat cable.
Is possibile to see Sat program on PC ? I need find a cable for connect sat and PC?
I have two antenna cable one the normal antenna and one the sat.
Exist cable for connect sat and PC?
