Re: Can't load Pluto.TV links?
I just noticed something, if I download the m3u8 with the browser and try to open the m3u8 file in browser it doesn't work, the m3u8 only has partial links like this:
572723/playlist.m3u8?terminate=false&deviceId=889540f0-712d-11e8-b9ec-8ba319deeadf&deviceVersion=37.0.2049.0&appVersion=2.0.0&deviceType=web&deviceMake=Chrome&sid=6e360db0-724b-11e8-be77-bf4d1417b012&advertisingId=&deviceLat=0&deviceLon=0&deviceDNT=0&deviceModel=Chrome&userId=&embedPartner=&appName=&serverSideAds=
Maybe that's the issue with ProgDVB? Is it basically downloading the link first then trying to open it? Like I said, opening the link (copy pasting the link in my first post) into VLC opens and runs the stream fine, but downloading the m3u8 in browser then opening the file in VLC doesn't work since it only has the partial links as in the code above.
Fri Sep 14, 2018 4:44 pm
ProgDVB open m3u but problem with links in m3u
So it downloads the link first? But you see it works in VLC if link is opened directly? https://stitcher.pluto.tv/stitch/hls/ch ... eviceDNT=0
The m3u file doesn't work in VLC either if you download the m3u, only direct link works. I guess I'll have to play around with the link and see if there is a more direct way to get to the stream.
