Can't connect to EPG
ProgDVB can't download xml-files, I've tried different URL:s that all work on my android apps but not on ProgDVB on Windows 10.
I have it on Swedish, and it's Swedish in the UI_updating.txt log below, but roughly translated the Swedish text in row 4 & 8 says:
"The underlying connection closed: An unsuspected error occurred when sending."
The same message comes as a popup when I try to update the EPG.
03:51.425 tmp file: C:\Users\...\AppData\Local\Temp\tmp2E6C.tmp
03:51.426 Guide : xxx - https://xxx.xxx/xxx.xml
03:51.609 Downloaded : https://xxx.xxx/xxx.xml (Guide : xxx)- result Den underliggande anslutningen stängdes: Ett oväntat fel uppstod vid skickande.
03:51.614 Error! ReaderEpg Size too small
03:51.615 0 EPG channels
03:51.615 report: Guide : xxx - Error downloading file https://xxx.xxx/xxx.xml !
Den underliggande anslutningen stängdes: Ett oväntat fel uppstod vid skickande. - Error!
03:51.616 AfterAllTasks
03:56.690 ChLogo TV4 HD SE(tv4) -OK
Do you know the reason for this?
Re: Can't connect to EPG
Yes. Some problem on https/ssl level in my software. Looks like some addition protection for https on this site
wget
Connecting to xxxx:443... connected.
OpenSSL: error:14077410:SSL routines:SSL23_GET_SERVER_HELLO:sslv3 alert handshake failure
Unable to establish SSL connection.
