transponder and iptv m3u8
without opening the transponder list in the notepad.exe (windows 10) ... how does one change or add a new transponder?
under sender list editor or manual search ... has little to nothing to do with new create a transponder ... I find these menus for pointless ...
it would not be bad if you could edit new transponder and iptv m3u8 files via progdvb ...
was just a thought
:wink:
Re: transponder and iptv m3u8
the stupid, after each update everything is overwritten ....
in which file can you change the german language of the program?
under sender list> manual search is "lock" what means lock?
and how to edit and sort stream channels for encrypted, tv and radio ...
So far, all channels are television programs
