Hi,
Since 5.x versions with SS1 in soft mode under XP, the channel properties show sometimes null before manual update, and very curious after (more mask than real value)
This can explain why zapping channels take many time or, if not working, need restart ProgDVB.
I have tried w/wo parse PMT in real time in options menu, w/wo can update in the channel properties.
Another more annoyant problem, when restarting working ProgDVB 5.1x, I got each time the following 0xC0000005 crash :
AppName: progdvbnet.exe AppVer: 5.11.5.0 ModName: progdvbengine.dll
ModVer: 0.0.0.0 Offset: 00004679
I can restart ProgDVB only by manually disabling StartDevice in the ProgDVB.ini file, then restart device after ProgDVB startup.
