Hi,
The problem is solved!!
I install KB896626 and it works.
The topic is irrelevant.
Kdst Rgds
Wolfgang
Hello,
I'm using a Hauppage WinTV-HVR 4000 card and a have some problems.
Using BDA-device for Hauppage WinTV 88X DVB-S/S2
Progdvb did not work properly ...
After a few minutes, sometimes seconds audio-sound was lost.
Premiere etc. works only a few seconds, then a window
"ProgDVBNet hat ein Problem festgestellt ..." appears.
Thank you in advance
Wolfgang
