As far as I have learned the hard way: No sat cards can be used for diseqc commands IF the operating system is Vista. Vista have changed the network structure and will therefore NOT accept WDM drivers.
Means ONLY BDA can be used.
- And BDA does NOT support the Disecq standard.
Only solution is to install XP,( which gives other problems), use WDM drivers (and forget about HDTV) or live with a half working (very) often crashing software from forexample DVBViewer. (every single channel change means software crash)
Or get yourself a set-top-box...
Correct me if I am wrong.
Hopefully someone out there will, and tell me it is not tru, that would make me extremly happy, I have a brand new PC, and a brand new sat card, new motor+a V-box and so on, and nothing works at all.. nothing...
Had hoped DVBProg maybe worked, but reading here on this board makes me belive it don't. ProgDVB only support WDM. Same goes for several other softwares, forexample Mytheatre and FastSatfinder.
BDA/Vista is a disaster for PC sat cards!!
