#1333
by H3lli0n
I've just upgraded to 6.94.2 and my problem of audio pin connector is worse !
Now it's not working either for HD ac-3 streams neither for SD Mpeg streams.
The dialog continusly appears :
-> if I click close progdvb crash
-> If I click setup the dialog appears right after validation and the loops is beginning
I can't use progdvb for both SD and HD now :/
19:56:57.107 - Video/MPEG2_VIDEO : MPEG2_VIDEO s={0,0,720,576}, t={0,0,720,576}, bmp=720x576, r=16/9, br=15305200,frametime=40ms, IF=0x0, CF=0x0)
19:56:57.132 - Add video codec 04fe9017-f873-410e-871e-ab91661a4ef7 - Pin for connection not found! 0x80040207
19:56:57.133 - CChannelGraph5::CreateRender 6
19:56:57.134 - VR: EVR
19:56:57.494 - Video pin founded. Try to founded any good codec... OK.
19:56:57.495 - СreateAudioPartOfGraph
19:56:57.495 - AudioType:MPG
19:56:57.495 - Audio/MPEG1AudioPayload : WaveFormatEx (2ch 48000 0bit formatTag= 0x50)
19:56:57.509 - Add audio codec e8e73b6b-4cb3-44a4-be99-4f7bcb96e491 - OK
19:56:57.528 - IMyGraphBuilder::CreateAudioRenderFilter::ProgAR:Périphérique audio principal OK
19:56:57.529 - Added audio processor
19:56:57.531 - AudioProcessor: Audio - {00000001-0000-0010-8000-00AA00389B71} - PCM - :CheckMediaType in MediaType (OK) 2ch, 16bits, 48000 samples
19:56:57.533 - AudioProcessor: Audio - {00000001-0000-0010-8000-00AA00389B71} - PCM - :CheckMediaType in MediaType (OK) 2ch, 8bits, 48000 samples
19:56:57.536 - AudioProcessor: Audio - {00000001-0000-0010-8000-00AA00389B71} - PCM - :CheckMediaType in MediaType (OK) 2ch, 16bits, 48000 samples
19:56:57.537 - AudioProcessor: Audio - {00000001-0000-0010-8000-00AA00389B71} - PCM - :CheckMediaType in MediaType (OK) 2ch, 8bits, 48000 samples
19:56:57.538 - Connect codec to AP - Pin for connection not found! 0x80040207
19:56:57.538 - remove and destroy AP
19:56:57.545 - Add and connect audio renderer - Pin for connection not found! 0x80040207
19:56:57.551 - Add and connect audio renderer - Pin for connection not found! 0x80040207
19:56:57.553 - ChannelGraph5::ReleaseSubClassesBeforSecondTry
19:56:57.578 - Graph::ReleaseAllFilters
19:56:57.588 - !!! DebugCriticalMesssages: Pin for connection not found! 0x80040207@FORMAT:MPG@@AUD_CODEC@@AUD_RENDER@
19:56:57.588 - !!! DebugCriticalMesssages: #graphbuilder#
