prog 6.12.01 - problem with second, pivoted screen.
when i move prog to my second screen, which is 90° pivoted, prog fails to recognize it. screen is 1280x1024 but due the pivoting it is in fact 1024x1280. prog is displayed fine, the vido is rotated as well, but streched in the wrong direction. so the picture is distorted to proportions 9:16 instead 16:9
http://img525.imageshack.us/img525/3484/prog1h.jpg window not streched
http://img525.imageshack.us/img525/3132/prog2.jpg window streched vertically
Subtitle doesn't save with ts file
#393Hi!
Subtitles works fine when watching live, but there's no subtitles in recorded .ts files.
Subtitles works with ver. 6.04.03 but not with 6.20.01
I have both versions at the same time. Is there conflict having both versions at the same time (different folders)
I'm talking 'bout finnish subtitles.
Thanks
Thanks
Broken or incorrect TS recordings since version 6.10?
#396Broken or incorrect TS recordings since version 6.10?
TS files recorded with ProgDVB versions since 6.10 show error in the TS when analyzed with TS-Doctor or Transport Stream Packet Editor tools.
The following error is reported: Warning: PMT PCR PID points to a PID with no PCR
Older version work ok
TSPE log loading recorded TS with ProgDVB 6.06.5:
Opening: K:\Eurosport HD - September 04 13 03 34.ts
Opening File...
Video Loaded.
Auto Finding PIDs
PID Attribute List:
PID: 0x0BB8: H.264 1920x1088 (1920x1080) @ 25.000 fps
PID: 0x0C82: AC3: 3/2.1: L, C, R, SL, SR, LFE 48KHz 384Kbit/s
PID: 0x0C85: MPEG1 Audio Layer 3, 56Kbit/s @ 44100Hz
TSPE log loading recorded TS using ProgDVB 6.10/6.20.1
Opening: K:\Eurosport HD - September 04 13 18 14.ts
Opening File...
Video Loaded.
Auto Finding PIDs
PID Attribute List:
Testing on Dutch Ziggo DVB-C
Opening File...
Video Loaded.
Auto Finding PIDs
PID Attribute List:
Opening File...
Video Loaded.
Auto Finding PIDs
PID Attribute List:
#398The problem is with all TS recordings made on all channels.Prog wrote:Do you have same problem on other channels?
I have made two sample packages with TS recordings made with DVBDream, ProgDVB 5.16.0 and ProgDVB 6.20.01Prog wrote:
Can you record me sample with correct TS from this channel?
The TS recordings made with ProgDVB 6.20.01 show the described error when using TSdoctor/TSPE
Mediafire: ProgDVB_TS_Test1.zip
Mediafire: ProgDVB_TS_Test2.zip
6.20.02: Overlay/Video Renderer problem?
#400With ProgDVB 6.20.02 I notice a problem with the Overlay (Video Renderer) screen mode.
Using Cyberlink Video/SP Decoder (PDVD7) with overlay screen mode a part of the picture is missing at left and right on SD channels.
Specially noticeable with 16:9 channels, resulting in a small box with cut-off picture.
Testing on same system with older versions 6.20.01 or 5.16.02 there is no such problem with the overlay screen mode.
Tested using XP SP3.
Re: 6.20.02: Overlay/Video Renderer problem?
#401Changing the demultiplexor mode from Microsoft to Elecard seems to 'fix' the overlay problem in ProgDVB 6.20.02.Doman wrote:With ProgDVB 6.20.02 I notice a problem with the Overlay (Video Renderer) screen mode.
I am not sure if it has the same stability as using the Microsoft demultiplexor.
nv4_disp.dll
#403When i switch between channel, sometime nv4_disp.dll do BSOD, i use latest 190.86 drivers on GTX260 card.
Other software never do it.
THX.
THX.
