I'll assume you are talking to me .. No i don't use any other skins but the default one.Prog wrote:Do you use some not standart skin?
It's name is "Skin 1" ...
Thank you for your concern,
OK - I have found the last working version for Diseqc 1.0 4-port with Skystar 1-CI (Twinhan) PCI under XP SP3 + .NET 3.5SP1 x32Prog wrote:Hm. What last good version? Same version is x32?
I have the same problembsdocuments wrote:ProgDVB v6.60.7
Bug = PIP Close Window Issue
Hi Prog,
there is a problem when using the PIP function, so here is :
when i get for example two channels as a PIP and i choose to close the first opened channel ProgDVB closes itself, and sometimes freeze or other things that may happen?! because channels that i've opened in PIP didn't work after the problem was accured,
Hope that you fix it soon
I copied these two files from version 6.46.6 to modules folder of 6.60.7.Prog wrote:You can take old bda.device and azurewave.ebda. Strange, no one report about same problem...
If we are sure that your equipment is configured correctly.(?) -reeven wrote:progdvb freeze, when i watch live-tv image freeze also.
Dvbviewer and Dvblink is almost perfect....
