Try add delay in Settings->Options->Scannersome frequency that say "not scanned" work perfectly if use MANUAL SEARCH on single transponder
#1232Nothing to do
With delay=2000ms this are results
http://postimage.org/image/80pp02qhn/
10.930 H 29.900 ie works perfectly with manual scan
#1233when "Channel Properties" is open and i change channel in the "channel Properties" in Transponder frame , satellite list will be duplicate , look at the picture you will realize my point : http://s23.postimage.org/6gkl52wiz/progdvb.jpg
another thing, it will be good if progdvb let us to disable "Internet TV..." & "IP TV Client".(they make some problem some times) for example after fresh install of progdvb when we should setup our devices for first time .... i cant uncheck IPTV & Internet TV (also there is no disable or remove button form them in the TV Source window).
another related thing: i switched "TV Source" window to advanced mode but now "Simple" button is disable and i cant back to simple mode.
Regards, FTA_Boy
Regards, FTA_Boy
#1234How you do that? Please send me screen of TV SOurces.
#1235here is a picture of TV Sources : http://www.p30up.ir/up/edcpbbzc1fmz06cq2w3k.jpgProg wrote:How you do that? Please send me screen of TV SOurces.
as i said : when "Channel Properties" is open and you change to another channel that happen, for each channel change the list will duplicate it self ...How you do that?
#1237I have a large number of satellites in my satellite list, so when i want to change to another satellite, i need to scroll through the satellite list. The bug is the cursor focus doesnt go to the satellite list when it is opened, it stands on the channel list, so cant use the mouse wheel to navigate the satellite list and choose another sat.
#1238I tested the last pre-release (6.92.1.c) and see that the infamous "AAC audio pin not found" returned back. The AAC audio problems are now some years old, may them someday be fixed?
And yes, we already know that it is not important, so developers desnt have time to fix it.
#1239This only experiment with types. In next version I am return types back.
#1240Please test (d) prerelease. This version must working with MS audio codec also.
#1241AAC still not working. Now problem is "Error audio codec to renderer connection without AP".
#1244Ok, aac audio working now. Codec dvix aac.
Last versions main aac problem is that the tv channel doesnt open, sometimes after 3 or 4 retunings it opens, sometimes never opens, with signal and quality present.
