Simple
EPG program list in same order as channel list in main program.
Please. Great program, thanks
#107
I miss an option do add custom ECMs in the CA module. Please take a look at DVBDream, you click the + or - there to add or remove providers. Something like this would be highly usefull.
also a there seem to be problems with the cnxcam module - some enhancements here would be highly appreatiated by TNK viewers
best regards and thnx for the best dvb soft ever!
#108
Its not Feature but improvement to scan can u make it faster?( like altdvb cause its takes too many time in scanning sat like turksat otherwise in alt.)
THANKS
THANKS
#109
I would like to see the tv stream as desktop background like DreamScene from WindowsVista.
If you could make this possible it would be very nice =)
Greetings Mazo
Greetings Mazo
#110
"I would like to see the tv stream as desktop background like DreamScene from WindowsVista.
Why ? 5 minuts toys?
"Its not Feature but improvement to scan can u make it faster?( like altdvb cause its takes too many time in scanning sat like turksat otherwise in alt.) "
What DVB card?
What DVB card?
#111
Twinhan 1025
also the prog ignore some transponders in scan and when i scan it alone it gets it
THANKS
THANKS
#112
Increase scanner timings.
#114
Depends on the version of ProgDVB.
On older versions you would add this to the ProgDVB.ini at the end:
On more modern versions you may perhaps find some general option for this.
But I can't tell precisely, as I'm bound to W9x for some days right now.
[Scaner]
AfterChangeTransponderDelay=3000
#115
What's the chances of being able to receive DVB/IP streams? I can receive them with TSReader, but the only way you csn view them is to dump the IP data to a file and then view it with VLC.
#116
thanks 4 ur addJuergen wrote:Depends on the version of ProgDVB.
On older versions you would add this to the ProgDVB.ini at the end:On more modern versions you may perhaps find some general option for this.Code: Select all
[Scaner] AfterChangeTransponderDelay=3000
there is no problem in older version (4.85.3) there is no ignored transponders but the problem in newer version (4.92.2)i tried to add
[Scaner]
i will wait u tell u change ur os to find this option in modern version (i tried to search but found nothing )
THANKS & WATING
EDIT:
i want to say something to PROG (the person)
first many thanks 4 ur great work & program
also that problem approx in all new versions please try to fix it
THANKS
#119
P> Request for the following resize/move picture functions.
P> Also, together with "resize/move picture functions" using keyboard
P> shortcuts is better:
P> 1. move whole picture upward.
P> 2. move whole picture downward.
P> 3. move whole picutre leftward.
P> 4. move whole picture rightward.
P> 5. stretch whole picture horizontally.
P> 6. stretch whole picture vertically.
P> 7. zoom in/zoom out (already realized).
P> 8. one shortcut key to restore the original size.
P> Also, add some preset options for various zoom settings is better.
P> These options should be user-defineable, I would like to set to 133% zoom, 109% zoom and 103% zoom.
Windows 7, 64-bit.
Twinhan AD-SP400(1041) DVB-S2.
KNC1 DVB-S2.
Technotrend S2300 Premium DVB-S.
Technotrend C1500 DVB-C.
Technotrend DVB-T TV-stick.
ATI 4550.
Asus Xonar HDAV1.3 Deluxe.
Creative S750 speaker system.
Latest ver.6 of ProgDVB Pro.
KNC1 DVB-S2.
ATI 4550.
4-in-1 switch issues
#120Waiting for your enhanced ProgDVB version with new switching method.
Hope it will resolve the annoying 4-in-1 switch issue lots of people are
experiencing now.
experiencing now.
Windows 7, 64-bit.
KNC1 DVB-S2.
ATI 4550.
KNC1 DVB-S2.
ATI 4550.
