hi.
I need to use SS2 on Win XP SP3. I`m use latest SS2 drivers 4.4.0
Device driver instaling ok. But then try instal soft, instalers return thys erore:
Found Windows XP Service Pack 3 ... Exit installation and upgrade to Service Pack 2 or higher
Hove to convince instaler, thet SP3 is higher of SP2????
Thenks
if use ld instaler (from native CD) - all ok, soft install done and work ok.
But hove to use latest soft and DRV???
It is a normal situations. Instaler was repared for Windows XP SP3 - version 4.4.3. Ver. 4.4.0 - instaler does not work in SP3, you must install all files from SP2 manually (old copy) or use software 3rd party.
Where I can download version 4.4.3 ???
Oficial website of Technisan now not have any files for SS2.
Give me link, pleas.
Nonsens....Oficial website of Technisan now not have any files for SS2.
http://www.technisat.com/indexf318.html ... ownloadtop
btw. what has this to do with progdvb ???
e... My mistake. I`m look on http://www.technotrend.com/ but not on proper site
thenks.
thenks.
I have feu problem on closing ProgBVB and open menu "setings" - "device list" But now all ok - version 4.4.3 fix my problem.SiLencer wrote:
Agane BIG thenks!
