Prog DVB 6.02-6.02.01 crashed after changing TV or Radio
The old Prog DVB 6.01.01Pro works perfect. But the new version 6.02Pro and 6.02.01Pro crashed, after Changing TV or Radio Channel. I have no plugins installed
Program closed with this Windows error:
Beschreibung:
Stopped working
Problemsignatur:
Problemereignisname: APPCRASH
Application Name: ProgDvbNet.exe
Application Version: 6.2.1.0
Application Timestamp: 4942cd3e
Fault Module Name: ntdll.dll
Fault Module Version: 6.0.6001.18000
Fault Module Timestamp: 4791a783
Exception Code: c0000005
Exception Offset: 00060267
Betriebsystemversion: 6.0.6001.2.1.0.256.1
Gebietsschema-ID: 3079
Lesen Sie unsere Datenschutzrichtlinie:
http://go.microsoft.com/fwlink/?linkid= ... cid=0x0407
My Configuration:
Vista Ultimate 64bit/SP1
P4Core2Duo 3,0GHz
Mainboard:Abit IP35 Pro, 4GBRam
DVD-S Technistat Skystar HD2
{BDA} DTV-DVB Mantis DVBS BDA Reciver Version 1.55 API Version 1.33
Dialog:Azure Wave(Twin Han)
DiseqC:{BDA}DTV-DVB Mantis DVBS BDA Reciver
Switch:Astra 1F,1G,1H,1KR,1L
Hot Bird 6,7A,8
DiseqC 1.0 4Port
Please can anybody help me
sorry for my bad english
Thomas
I tried to disable Prog Media Server in Settings->Module list
and there is a new Windows error
at (Int32 , UInt32* , Int32 )
at ...(Int32[] , Int32 MaxOutPower)
at ProgDvbNet.EqualizerPanelControl.(Object , EventArgs )
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.1434 (REDBITS.050727-1400)
ProgDvbNet
Assembly Version: 6.2.1.0
Win32 Version: 6.02.01
CodeBase: file:///E:/Program%20Files%20(x86)/ProgDVB/ProgDvbNet.exe
EngineApiWrapper
Assembly Version: 1.2.2.0
Win32 Version:
CodeBase: file:///E:/Program%20Files%20(x86)/ProgDVB/EngineApiWrapper.DLL
msvcm80
Assembly Version: 8.0.50727.1434
Win32 Version: 8.00.50727.1434
CodeBase: file:///C:/Windows/WinSxS/x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.1434_none_d08b6002442c891f/msvcm80.dll
System
System.Drawing
ProgDvbNet.bc
Assembly Version: 1.0.8.0
Win32 Version: 1.0.8.0
CodeBase: file:///E:/Program%20Files%20(x86)/ProgDVB/ProgDvbNet.bc.DLL
IPDev.Skins
Assembly Version: 1.3.5.0
Win32 Version: 1.3.5.0
CodeBase: file:///E:/Program%20Files%20(x86)/ProgDVB/IPDev.Skins.DLL
ProgDvbNet.EPG
Assembly Version: 1.0.3.0
Win32 Version: 1.0.3.0
CodeBase: file:///E:/Program%20Files%20(x86)/ProgDVB/ProgDvbNet.EPG.DLL
ProgDvbNet.CC
CodeBase: file:///E:/Program%20Files%20(x86)/ProgDVB/ProgDvbNet.CC.DLL
System.Xml
ProgDvbNet.Win
Assembly Version: 1.0.0.0
Win32 Version:
CodeBase: file:///E:/Program%20Files%20(x86)/ProgDVB/ProgDvbNet.Win.DLL
Accessibility
System.Design
System.Drawing.Design
System.Configuration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
enabled.
For example:
<configuration>
</configuration>
Thomas
Same problem here. I placed a similar post in bug reporting. Sorry for the double!
By the way, it happens also if you leave progdvb running for a while with no apparent reason.
Skystar HD on Core2 Duo 6420
With ProgDVB Professional of course :-)
Similar problems for me. After update of ProgDVB standard from 6.01 to 6.02 and 6.02.01 I have constant crashes. ProgDVB will run for 30 seconds to 5 minutes before I get the message "ProgDvbNet has encountered a problem and needs to close....". The video and sound continues to run if I don't close the pop up message. As soon as I try to change channel or use time shift ProgDVB freezes totally. When this happens some times the BDA-driver is also crashing and I have to reboot my PC to get it working again.
I have the same problem. Progdvb 6.02.01 crashes without a reason few minutes after start. Moreover, sound disappears when changing to full screen. Media Server and Audio Processor are disabled.
Any idea?
Hauppauge DVB-C Mod. 727 operated as 'Sky Star1 over TT - Soft mode'
C2Q6600, 4 GB RAM, WinXP Prof 32, Radeon HD3650 512 MB DDR2-RAM
Displays: 19" TFT & 19" CRT for TV
OK. This conversation is a little slow so I will fill in as much information as I can to speed it up. :D
WinXP professional, fully updated.
Radeon 9800 PRO with Catalyst 8.12
Watching FTA DVB-T with TechnoTrend with latest BDA driver
No pluggins at all.
Nvidia video decoder.
VMR7 and VMR9. Both tested
Elecard audiodecoder.
System default directsound device.
No subtitles in the stream.
EPG in the stream.
Teletext in the stream.
Modules:
PID recorder disabled.
Prog Media Server(Home) disabled.
Device list:
BDA.Device active (Generic BDA)
ITV.Device active
Options:
Use Audio Processor, disabled.
Time Shift Buffer in memory, default values.
Scheduler, disabled.
Always parse Teletext and EPG, tested on and off.
Enable CAM interface, tested on and off.
Use only one CPU, tested both on and off.
One thing I noticed is that in pull down menu File-Properties under Filters i can find "FilterStartClock 0001" or "FilterStartClock 0002" which I have never seen before. It is not there direct at start but every time it crashes it is there.
#15
I usually meet with the crash issue when I close ProgDVB after watching for a long time (>1 hour). Only switching TV channels during ProgDVB open is not prone to crash.
Often, during ProgDVB startup, it will halt and then crash.
I'm using Vista 32bit w/ all modules disabled, audio processor disabled.
EVR. ffdshow audio codec and Cyberlink PowerDVD8 SP video codec.
Windows 7, 64-bit.
Twinhan AD-SP400(1041) DVB-S2.
KNC1 DVB-S2.
Technotrend S2300 Premium DVB-S.
Technotrend C1500 DVB-C.
Technotrend DVB-T TV-stick.
ATI 4550.
Asus Xonar HDAV1.3 Deluxe.
Creative S750 speaker system.
Latest ver.6 of ProgDVB Pro.
