no radio filter seems to work
hi there!
i'm quite happy about progdvb - and have been for some time now! sometimes a little fine-tuning is needed, but then usually everything works fine. This time, though, a can't find a solution.
tv is working fine, video as well as audio. But as soon as I switch to a radio channel, no filters are loaded (File -> Properties -> the list is empty here). I tried every filter so far, but nothings happening...
I installed the new 4.80.2 elecard version (although I stick with my Cyberlink filters as they a) seem to give a better picture and b) also upmix the stereo signal to a 5.1 signal very well)
do you need any more infos? (also: progdvb from another folder in which i copied the old version 4.72.6 works fine on radio as well as tv)
any ideas?
thx!
