Hi:
I have a little sound noise in my progdvb and it is not solve by changing any codec. when i mute the progdvb the noise stop and it show that the noise is from this software.
what can i do?
but then gain control from Progdvb is not working anymore !!mnmlnet wrote:I solve this problem in the options/audio and NOT selecting use audio processor.
#6i have tested with standard settings. the sound is making bad noise after 2 minutesProg wrote:Please test this http://test.progdvb.com/ProgDVB6.06.2.TestPro.exe
in latest progdvb the same ...
tested and little more better but problem not fixed !!
increasing timeshift size causes new problems in sound ...
other prob, channel change time upto 2-3 seconds in other dvb players under 1 second !
but most problem is sound asynchron and bad noise cratching sound
i have same sound probs on 2 different PC systems !
my own is realtek HD onboard and on second pc there is pci card creative x-fi and both systems produce this bad noise !!
what can we do to avoid such problems ?
i have tested different codec filters and with audio processor option enabled/disabled but same result
hmm not really ...
all kind of channels are getting crazy after some minutes and produce very bad sound effects !
Yes, it is true. Temporary solved: audio renderer - WaveOut device, but this bug is reproduced for realtek HD device.rotarum wrote:i have same sound probs on 2 different PC systems !
