Dear ProgDVB support team,
I am using Huawei e510 TV to watch TV through dvb-t. The attached programme TotalMedia TV 1.0 is working just fine, except for that I am working on a dual monitor setup and can not move the TV window to the second monitor.
That's why I was trying ProgDVB instead. It seems to accept the dvb-t tuner but for some reason I can not find any channels with that programme neither in the normal search nor in blind search mode.
My device is set to "{BDA} HUAWEI BDA Digital Tuner (Dev1 Path0)", Device Options "Automatic". I have two green bars at the bottom of the programme, both showing "100%".
I would appreciate any help to get the programme running. Thank you!
best regards,
Karl
To be honest, I don't really know how the transponder scan works. I can click on "lock" and then "scan" but nothing happens. Here is a screenshot of the transponder scan window:
I can't. I'm located in Austria which is missing in this list. Should I just select any other country?
I tried a blind search with the standard parameters, but was not luky - same problem - no channels can be found. Settings: from 470 to 860 Mhz, Steps 2, Symbol Rate 7000.
What parameters do you recommend for the blind search?
Unfortunately I do not know the data for the channels available here. I can export a channel list from TotalMedia TV but it can not be read with your programme or an editor.
Normally such parameters are published on the web site of the providers (content or technical), or they can be found on some general TV related local pages.
In many cases it's enough, to enter a seed (~ main) channel manually, to get started.
not working either. Pretty weird...
Maybe I can only use the original programm and no third party one...
[url=http://www.sputniktv.at.ua][b]Спутниковое ТВ и Интернет[/b][/url]
Both try to play around with device settings. "Automatic" may fail on some tuners.
