6.03.03, i like it most, tried 6.10 but i did not like channel list.
6.05 Pro did have strange color background under text and it was too large on the screen.
I have used this in Win XP Pro (finnish) without any problems, now i upgraded Vista Home Premium with SP2 and installed same version and in few minutes watching, all faces (example) turns very green, sky is not blue, it turns to purple and so on.. If there is black/white program, it is ok
Any help ?
#31. I do not like this kind of list, which is circledProg wrote:1. What problem with channel list?
2. You can try change video render. (Settings->Options->Video). Or update driver of video card (it is bug of video card)
Liked old version better where was only channel name
http://www.uusikaupunki.fi/~passaari/donotlike.jpg
2. Latest drivers, all updates, Vista Home Premium, SP2, Geforce 9500GT
I changed it and now testing..
btw.. I upgraded to 6.11.03 (still goes green but now changed settings)
i had same problem, just change video renderer to which ever makes it not greeny yellow ..
maybe same problem
maybe same problem
