what you can try is install orb on your pc. start recording with progdvb and stream the record file with orb. when you log into orb website you can view your recorded file on basicly anything. i stream to my dads house using orb and the quality is outstanding.
yeah i was looking at orb a while back for my nokia n95 8gb but i dont like the idea that the program has to be connected to the internet :( any other way?
Is a windows mobile & is wifi'ed so there's gotta be some program that supports it.
What are the codec if i selected Shoutcast under prog media server
Intel P4 HT 3.00ghz
3GB Ram
256MB ATi x1500
AVerMedia DVB-T Volar X (A815)
