by Juergen
This is far off topic, for a place dedicated to ProgDVB, and nothing else.
Anyway, you should check the other disk with the system control of the Windows version working, drive manager. May be, it does not have any partition on it, or even no partition table. Or the partition table / partitioning was not made on the controller it's attached to now. Better do it again from there.
If you are using any tool, for setting a primary partition to active and the other inactive (or hidden), let it be. Normally all Windows versions rely on exactly one Master Boot Record on always the same disk.
Another disk should only contain logical drives in an extended partition, as else some severe confusion of drive assignment may happen, specially by possible changes between install time and normal use.
If your first disk was PATA / IDE, but the second one a SATA type, installing another Windows there to is supposed to fail, due to missing SATA drivers at that time, or conflicts with native resp. compatible IDE mode in the BIOS setup.
This is exactly, how far we can go here now.
This for, TOPIC CLOSED.
You're warned, ProgDVB related discussion only.
