Hello,
My progdvb crashes aleatory when changing channel. I have a Nexus in Software mode. The module involved seems to be quartz.dll at always the same address...
I have been patient and tried each new version, reinstall even windows XP twice but still the same issue. aleatory, progdvb crashes...
WHen i chnage the filter, then it crashes at another address and remains at the same address until i change the graph.
Please.... help me. give me some ideas.
Nvidia Graphic card, WIndows XP latest pathes and nothing else than Progdvb installed...
Thanks
Cedric
Hi , strange ...i have no such problems here with my cards ......
P4,3.2 GHz,2 MB Cache,800 MHz FSB,2048 MB DDR-RAM,320 GB HD,GeForce 6800 GT u. Athlon 1400 auf Asus A7A266,512 MB DDR,GeForce FX 5200 mit 128 MB-TV-Out,3x80 GB HD,500 GB ext. HD,DBox1,Nova-T USB Stick,Skystar 2 (Treiber 4.40)+ Hauppauge Nexus 2.1 (Treiber 2.17g)Quad-LNB auf 19.2° Ost,Hauppauge DVB-C (Treiber 2.17g)u. PVR 350, WinXP PRO SP2 + DX 9 c,Firefox 2.x,Elta 8883 MP4 - DivX-Pro-DVD-Player,Progdvb 4.80.x,4.79.x,4.56.2 u. andere (3 Karten Simultanbetrieb - DVB-T + DVB-C + DVB-S in 4.80.x),DVBDream 1.3x,DVBViewer Pro 3.501,Ritzdvb 0.8.1.3 u. My Theatre 3.36,Alphacrypt 2.03....
Hello,
OK it works fine for you but not for me. You do not have the same configuration, that might be the reason why.
I am trying to find a solution to my problem.
I saw report from other that have teh same problem.
The module that crashes in WIndows XP is PROGDVB, so my guess is that there is a problem with progdvb, right?
So if you cannot help me, may be someone else in the forum can.
Thanks in advance!
Thanks in advance!
quartz.dll - may be problem in BIOS or hardware, try to update and optimize your bios settings or use specific drivers for motherboard and perefirial devices.
[url=http://forum2.progdvb.com/viewtopic.php?t=31]DISEqC 1.2 module for ProgDVB[/url]
@cedricj,
Have you sorted out your problem as i seem to have the same think happening to me when i change channel it crashes.
Please let me know how you sorted it
Regards Jono
Regards Jono
different hardware, same problem.
ecs nforce3, amd 3200+,ati radeon 9600pro 256, skystar2,xp sp2,drivers and patch last versions. progdvb 4.80.5
Always I change channel quartz.dll crashes.
No one have idea?
No one have idea?
Seems like the quartz.dll crashes are an unsolved mystery. I have the same problem, but there seems to be no definitive help on the issue
Pentium 4 2.4 GHz
1.50 GB DDR400 (PC3200)
WinFast A340 T GeForce FX 5200 128MB DDR, Forceware 162.18
Pioneer 16x DVD-106S, LITE-ON DVDRW SHM-165P65
Creative Sound Blaster Audigy
Creative PC Works Speakers
ASUS My Cinema-U3000Mini
Windows XP Pro SP2
Windows XP Pro SP2
