Hi, is there some way to get rid of Elecard MPEG2 Decoder ?
It was a accident that I installed it, and now I don´t know how to delete it.
Ok, now that I uninstalled it,
everytime I start ProgDVB or change a channel I get the ErrorMsg:
ProgDvbEngine
Error ! Filter not Founded !
"Elecard_MPEG_2_Video_Decoder" -
when I klick ok, the MsgBox disappears and I can watch without problems.
But it sucks that it always appears.
ProgDvbEngine
now you have to register elecard codec again(or use other codec ) ->\progdvb\filters\register.bat
You need to build graph on your codecs installed on system. All problems in codecs. Try to use Cyberlink or InterVideo...
[url=http://forum2.progdvb.com/viewtopic.php?t=31]DISEqC 1.2 module for ProgDVB[/url]
@oNe3
What do you mean with "build graph on your codecs" ?
I want to use Nero Decoder or the Ati Avivo Decoder, how do I do that?
you have to build a proper filtergraph if you want to use a codec in progdvb....for this use graphedit (included in progdvb package)...
http://msdn2.microsoft.com/en-us/library/ms787460.aspx
Sorry for my englishStingrey wrote:@oNe3
Each codec have unique ident in registry. And you need to use demultiplexor and audiodecoder on your choise, and use Avivo VideoDecoder to render mpeg stream.
P.S. Quality of Avivo dont like for me, and minus for this codeks - his dont have settings...
ok, I checked out GraphEdit.
Man are there some Tutorials out there?
What codec would you suggest?
BTW, use the notepad / editor, to look inside of and perhaps edit the .bat files.
The routine for other codecs (not yet available from the system) is similar.
Of course you've got to have the codec you want to install, either in a windows known path, or in the same folder.
