Re: ProgDVB V6.41.1 std (Freeware)
#4+1!
PC: Windows 7 x64, PIV 3.00 Ghz, ATI HD4670, 2GB RAM.
Devices (for testing pruposes): Prof 7301, Prof 7500, TBS6980 Dual tuner, TeVii S470, TeVii S660, TwinHan 1020 Blue, AverMedia 007 DVB-T ... and many other old AnalogTV Cards...
- Sorry for my bad English!
#6TBS6980.Prog wrote:to Cjcr & Cobin: Do you have same problem? What DVB device?
This card need own bda.dev for working with ProgDVB. When install new update of Progdvb, the installer replace my bda.dev for another one. Only fix for this is rename my own bda.dev to other name like tbs_bda.dev or similar.
#8Do not tune to any channel.
#10Yes. When use the bda.device get this signal: L: (Variable)%, Q: 0 %.Prog wrote:In all version of ProgDVB?
Same without diseq?
with own bda.device provide with tbs minidisc works well.
Rare issue,... same for other dvb players.
#11With TBS tuners?
Try this:
Try this:
#12Try this TBS_device_for_ProgDVB_-BDA-..zip
if i try this with current ProgDVB Version on my system (current BDA File is more than twice the size) nothing will be received at all.
I have Win 7 64bit with i7-975 and nvidea 9800, TBS 6980, latter may be the reason...
regards,
regards,
