Hi,
finally I got my System working quite smoothly and I have only one issue left:
How to set up the channel list to allow for recording a program from one receiver channel and view annother program from second receiver channel?
To my expectation the way it works could look like:
1. Search both receiver channels to end up with two lists.
- remark: Unfortunately it is not possible in channel properties to check if I really did because visible parts of strings in displayed area is too short.
2. Select List for tuner a and display epg
3. schedule recording
4. while recording select other list and view annother program
is this the expected way it should work?
Does the epg record select default to some 'preferred' recording channel or does it take the receiver channel to record from according to the currently active list?
-remark: unfortuantly I don't see indication for recording source (channel 1(A) or 2(B) ) in EPG or sheduler entry.
I'd be glad if somebody could help me understanding what's going on, because for me it currently looks like the expected way does not work out.
best regards,
A. den Toom
