you are using cable settings !thehoff wrote:meh, i cant get 2.04 to work...when i start i get an error msg and when i try to load a bouquets.xml file it crashes too with an error msg.
i already installed .net 3.5, but stil lthe same probs.
here the first error:
System.ArgumentException: The currency separator information specified in the NumberFormatInfo is ambiguous for parsing.
second one when opening the xml:
System.ArgumentException: Argument 'Length' must be greater or equal to zero.
edit: here another try to open or import an xml file:
System.IndexOutOfRangeException: Index was outside the bounds of the array.
well, i haven't test it with cable tv...
i took the def's from side: http://wiki.tuxbox.org/Bouquets.xml#satellites.xml
and
http://wiki.tuxbox.org/Bouquets.xml#bouquets.xml
and i haven't seen how it is on cable tv.
it looks for me like the sat version but some differents ....
on cable:
<transponder id="2713" onid="f001" frequency="394000000" inversion="2" symbol_rate="6900000" fec_inner="0" modulation="5">
<channel service_id="c3b5" name="Fashion TV" service_type="01"/>
on sat:
<cable name="Kabel Deutschland">
<transponder id="041e" onid="0001" frequency="10788000" inversion="2" symbol_rate="22000000" fec_inner="0" polarization="1">
<channel service_id="768e" name="TAQUILLA 1" service_type="01"/>
on cable there is "<cable> and a "modulation" ???? what should it be on progdvb ? do you have settings from progdvb with cable ?
on sat there is <sat> and the "polarization"
also i haven't try cable-tv on Progdvb
for that i had to be get cable settings from
also on bouquets.xml there are alos some differents ...
<?xml version="1.0" encoding="UTF-8"?>
<zapit>
<Bouquet type="0" bouquet_id="0001" name="ARD" hidden="0" locked="0">
<channel serviceID="6dca" name="Das Erste" tsid="044d" onid="0001"/>
"Bouquet type" ??? bouquet_id ???
and this is not define in http://wiki.tuxbox.org
so there are some open issues which i doesn't know... or maybe it is better you take another editor
cu camel
