ProgEdit 2.04 - ProgDVB Channel Editor 21.12.2007
history:
ProgEdit - ProgDVB Channel Editor v.1.110 28.12.2006
+ fix - sometimes the AC3PID implent wasn't always read
+ fix - changes for "current audio pid" wasn't applied
+ fix - SDX files import works now again - some UINT16 vars to UINT32
+ fix - DVB files import works now with FEC and AC3 Audio PID
(i'm wondering about the DVSO DVB definition - sometimes flag to ac3 or crypt mode ??
+ try to fix FEC handling for all import types - only "FEC 0 // 1/2 // 2/3 // 3/4 // 5/6 // 7/8 //unknown" possible
ProgEdit - ProgDVB Channel Editor v.1.109 21.09.2006
+ fix - for import of dvb-files (loading AudioPid)
ProgEdit - ProgDVB Channel Editor v.1.108 25.08.2006
+ fix - overwriting with file channelnames.txt
+ fix - no new resort after adding channels to channel list
+ fix - some small bugs on channel list handling
+ fix - neutrino special chars converting
+ fix - neutrino UTF U8-Unix format for linux boxes - now it works to use it directly
ProgEdit - ProgDVB Channel Editor v.1.107 13.06.2006
+ add new column in channel list -> it shows, if a channel is not in channel list tree
ex: if you load a channel tree, then the programm will check if it is in list or not (MARK with "No" or "Yes")
ex: if you "add" a channel to channel tree -> then it will be mark with "Yes"
ex: if you "remove" a channel from channel tree -> then it will be mark with "???"
ex: because i can't know if this channel is somewhere in a other node tree, and so it is unsure
ex: if you save then the channeltree and load the channeltree once again it will check the full channeltreelist
ProgEdit - ProgDVB Channel Editor v.1.106 25.05.2006
+ new option on column "#" -> there is a small button "A", which rewrite the internal channel# as it is sorted
+ fixing bug on "add" (copy) an existing channel with all lngstream data
+ fixing display on scaling
ProgEdit - ProgDVB Channel Editor v.1.105 25.05.2006
+ fixing bug on modifying the type in lngstream on saving
+ fixing auto-position after deleting a channel in channlist-tree
ProgEdit - ProgDVB Channel Editor v.1.104 24.05.2006
+ fixing bugs for channels with 5 digits satelites
ProgEdit - ProgDVB Channel Editor v.1.103 13.05.2006
+ fixing bug on saving channel lists without having device information on achannel
ProgEdit - ProgDVB Channel Editor v.1.102 12.05.2006
+ fix sdx extension
+ add all extensions to open/save/import dialogs
ProgEdit - ProgDVB Channel Editor v.1.101 10.05.2006
+ fix on doublechannel-errorlist was't visible
+ add checkbox for enable/disable checking for doublechannels in list
ProgEdit - ProgDVB Channel Editor v.1.100 10.04.2006
+ in modus channel tree list - fix loading/saving "group by", "sort by", "TV, "Radio" and "Other"
ProgEdit - ProgDVB Channel Editor v.1.099 29.03.2006
+ in modus channel tree list - now also position to the selected channel (if channel exist in list) in both lists incl. fill out the fields
+ in modus channel tree list -> also move channels from one tree to another tree ("UP" and DOWN" button)
ProgEdit - ProgDVB Channel Editor v.1.098 11.03.2006
+ after channel select -> show/set channel lngstream to current audio pid (easier see the language)
ProgEdit - ProgDVB Channel Editor v.1.097 07.02.2006
+ new function - support for neutrino settings (services.xml, myservices.xml, bouquets.xml)
+ new function - button "new" channel list will reset to an empty database and set default valueas for header
+ new function - delete all double channels (in priority it will first delete the channel where no PCR is inside
+ warning on exit
+ "cancel" button wasn't handled correct (on all dialogs)
+ fixed import von Satco, DVB
+ fixed - delete the last channel in list was a problem>
+ some new fields for neutrino databases (they are a little bit gray)
+ new column in channel list (for channel types - TV, Radio, etc - but must make with graphic symbol in list)
+ automatic detection on open neutrino files (services.xml, myservices.xml)
+ overwrite channel names also with Neutrino (services.xml, myservices.xml) possible
+ fixed - import of *dvb files
+ fixed - a lot of problems with channel list and different versions
+ fixed - a lot of problems with channel list trees and different versions
+ new fields - support for neutrino settings (services.xml, myservices.xml, bouquets.xml)
+ field PCR noiw handle in one field for all versions
+ a lot of fixes on changing and saving all datas correctly
ProgEdit - ProgDVB Channel Editor v.1.091 01.02.2006
+ fixed - double channel error list was not displayed
+ fixed - in "header tree info" name of channel tree list - have now more width for longer names
+ fixed - in "header tree" and "header tree info" all changeable options have now the old default value in inputfield
+ fixed - in "header tree" and "header tree info" all changeable options have now a check for emtpy inputs
+ fixed - all dialog for filehandling now also cancel handling and stop operation - also if it is empty
+ fixed - PMT and VIDEOPID was wrong view in the channel list
+ fixed - Import of DVB files - now works , but think .- there are not all values in this file structure.
+ fixed - saving after import will work, but i prefer to input some things per hand in the channel list after that
+ fixed - "overwriting channel names" - i made an better trim , that the tool will also work with tab delimited and
also with "blank delimited" will handle correct
ProgEdit - ProgDVB Channel Editor v.1.090 31.01.2006
+ convert from old channel list to new channel list (ProgDVB 4.53-4.7x) incl. full test (see FAQ how it works)
+ convert from new channel list to old channel list (ProgDVB 4.7x-4.53) incl. full test (see FAQ how it works)
+ convert from old channel tree list to new channel tree list (ProgDVB 4.53-4.7x) incl. full test (see FAQ how it works)
+ convert from new channel tree list to old channel tree list (ProgDVB 4.7x-4.53) incl. full test (see FAQ how it works)
+ building of complete new channel list without a base of ProgDVB file - works for all versions (ProgDVB 4.7x-4.53)
+ building of complete new channel tree list without a base of ProgDVB file - works for all versions (ProgDVB 4.7x-4.53)
+ a lot of fixes for empty files on channel list and channel tree list
ProgEdit - ProgDVB Channel Editor v.1.080 30.01.2006
+ fix a lot of errors in channel tree - now should works also for brand new channel list tree per hand
+ fix on adding multiple channels to channel list tree
+ fix on "name to service" on multiple channels
+ fix - if change an existing channel - then it wasn't in the channel list tree anymore -> fixed
+ i checked byte per byte, that the changed channel list and trees are correct like ProgDVB
+ add function "Overwriting channel names". This will overwriting names and use "ChannelNameTable.txt" (see manual for details)
+ add structure changer for channel list tree (so you can also mod an old chaannel list tree for new structure, too
+ add changing name of channel list tree
ProgEdit - ProgDVB Channel Editor v.1.071 27.01.2006
+ fix crashing on loading channeltrees which have empty folders inside
+ fix structure if importing old an new progdvb channel lists
ProgEdit - ProgDVB Channel Editor v.1.07 26.01.2006
+ full support for ProgDVB 4.53 - 4.7x (included channeltree)
now i fixed the differents in new channel and channeltree structures
it was really crazy !!! - but anyhow - it's done !!!!
ProgEdit - ProgDVB Channel Editor v.1.062 10.01.2006
+ now you can also change the versions-number of channellist
(see above structure changer)
+ ? channeltree structure maybe also changed from prog - hmm ? - but better wait for a real stable version
of 4.7x otherwise i can make changes for almost every version
ProgEdit - ProgDVB Channel Editor v.1.061 09.01.2006
+ full include of new channel structure of ProgDVB 4.7x
(DeviceID.m_SubID // DeviceID.m_Type // DeviceID.m_DllID
ProgEdit - ProgDVB Channel Editor v.1.06 03.01.2006
+ channel tree info list
+ fix on show double-channel-error-list
+ selecting the error-channel in doublechannelerrorlist (for easier delete of channels)
+ create a new channel tree list also possible now
+ works now with new channel version (ProgDVB 4.70.x)
ProgEdit - ProgDVB Channel Editor v.1.05 29.10.2005
+ fix bug in add to channel list tree - and correct position (it was added only at the end) now it is correct position
+ fixes for error list - now you can multiselect the channels in error list , then hide the list and then you can delete the double at one time
ProgEdit - ProgDVB Channel Editor v.1.04 28.10.2005
+ new index + sort options also for error list
ProgEdit - ProgDVB Channel Editor v.1.03 28.10.2005
+ added error list - this check on load/save/import/delete/modify/add/ if channels are double in the list and if error then you can show/hide/edit the errors
+ fixes for multiple deletes - if the columns are special sorted then it delete some wrong channels
+ fixes for import of *.dvb files
ProgEdit - ProgDVB Channel Editor v.1.02 26.10.2005
+ fixes for up/down/left/right modes in channel list tree
+ fixes for import of *.dvb, *.dat files
+ all buttons now works
+ updated help-file
+ fix for different colors - handle for special *desktop color programm*
+ fixes for saving the channel-tree
+ fixes for fu..ing treeview - complete new handling and parallel db (channeltree + treeview)
ProgEdit - ProgDVB Channel Editor v.1.01 beta 20.10.2005
+ support for channellist tree - there is a new button top/left
then you get an new design"
This is only for testing - not savin of channel-lists now possible"
because something is strange in the structure. I have not finished - waiting for infos from Prog
+ import for *.dvb
+ import for *.dat (ProgDVB) -> then it will add all channels from file
and not clear the list which was before
+ updated help-file
+ fix for different colors - handle by stranger *desktop color programm*
+ extra sort of multiple lines by sortorders now also possible
ProgEdit - ProgDVB Channel Editor v.1.00 16.10.2005
+ new help-file readme, manuals, faq, ....
+ new buttons for Open+As, Save+As, import
+ structure changer
+ small "add" and "modify" with empty fields also possible
now no error if some info are missing -> the programm will filled all necc. infos or to "0"
+ fix for loading errors
+ fix on "add" and modify a channel - now also poss. with empty fields
+ cosmetik
+ the next field can also reached with "Enter-Key" -> then the next field will active and text marked
+ "all select" in list button above-left the viewlist and also if the window viewlist ist active
you can also press "a" button to select all channels in list
+ user error catching
+ end of beta phases - first final version :)
ProgEdit - ProgDVB Channel Editor v.0.80 15.10.2005
+ fix a lot things with load, save, delete, import.
+ file-info (top right - now looks fixes)
+ user-error-handling
+ "add" and "modify" with empty fields also possible
+ cosmetik
ProgEdit - ProgDVB Channel Editor v.0.7b 14.10.2005
+ import now possible for SATCO-files (the the file must be called "*.sdx")
sorry - but in satco there is no information about the "AC3-AUdio PID"
imported channels will be named with text in "provider" and "network" -> " Prog Edit" and "Imported"
+ cosmetik
+ fix on "add" a channel
i think the first version which can realy use - without an high risk to damage the channel-settings :)
i test so much and i tried all kinds of loading, saving, delete, add, modify, -> and after that always hex-compare of structure and files
all before was only for testing, helps to fix bugs, but now this seen to be STABLE !)
ProgEdit - ProgDVB Channel Editor v.0.7 14.10.2005
+ cosmetik - new arrange and design
+ cosmetik-timer for some events to measure (load, save, import, ......)
+ extra function to use the "caption 2 service" and also for other direction
now you can take the names from caption and let automatic import to the "service" -> also other direction
(there is a new field(label) between "caption" and "service" -> this you can also click and you'll see then what heppen.
this also works in multichoice
+ marked the labels there inside drark-blue) -> so you better see what you can click in multi-choise to use for changes
+ small fixes and code optimzed and better for reading for the other guys :)
ProgEdit - ProgDVB Channel Editor v.0.6g 13.10.2005
+ fix bug on load and save lists (if channels was under 40 channels then it crashed -> fixed
if you load a list and then save the listz - there were small differents - it's fixed
+ cosmetik and some informations more in the header (top right)
+ sort orders are now correct and also on search
+ "enter"-key handling for the most fields (step auto to next field, or on search -> start search and search again..)
+ ! support for old and new channel handling :
! read every byte as it is and the same format as read back (on "save")
+ also i add my channel.dat incl. (astra+hotbird) and channeltrees for: 1x favoriten, 1x provider, 1x transponder (also PPV senders renamed)
if somebody have also some good lists let me know
ProgEdit - ProgDVB Channel Editor v.0.6e 13.10.2005
+ a lot of cosmetic
+ correct the input and out fields (ac3, and pff also the crypted flag)
+ error handling
+ new design
+ cleaning some code lines
+ resize of lists
+ some things for better handling
+ bug fixes on loading, saving ... (if yyou only have 1 channel inside ProgDVB have a problem - so it is a must >2 channels in list)
! on big changes ! - you must reorganize in proggdvb the channeltrees.
! or also it is possible, after BIG changes (import or add much senders) -> that you have to switch at first to a channel.
! and then you can open the channel-proberty window without an crash
! i think this is a problem of lastchannel-actived in progdvb and there is no error handling ... maybe ..:)
! if you don't delete "the last activeed channel" then this problem is not happen :)
! -> SO after big changes -> on first start progdvb -> switch to a channel :)
ProgEdit - ProgDVB Channel Editor v.0.6b 12.10.2005
+ a lot of cosmetic
+ cosmetic arange for search and import function
+ order from all fields ...
+ resize of list - rebuild
ProgEdit - ProgDVB Channel Editor v.0.6a 12.10.2005
+ load also old and new formats of channels
+ autochannel number
(if you marke some channels you can input the starting number in channel field and click before to the
channel-label til it is changed to "AutChan" then it will change the numbers from start number and the mext one + 1)
+ error handling on load lists
+ "ADD" -> also it is possible to "add" new channels - also on complete empty lists
ProgEdit - ProgDVB Channel Editor v.0.5a 12.10.2005
Changes: 0.5a - (basis 0.4b DarkFritz - mods from camel)
+ multiple choice
.) modifications on multiple channels
all fields which are active will changed if you click on modify
(there you can click on the labels to active it)
All fields which are active will changed also in selected multiple channels choice.
Ex: "if you want to change 5 channels and there you want only to change the Provider"
1.) mark your 5 channels (CRTL or with SHIFT first and last mark - like MS windows)
2.) click the label "Provider" (then the field “Provider” is active and you can change the name there
3.) click on button "modify"
.) delete on multiple channels
only mark all channels and then press "delete"
+ list complete with some good infos
+ sorting of the list
+ a lot of cosmetic - field orders and so on ....
SOME IDEAS - TODO:
NEW:
Double channel error list - maybe an option where all double channels can easy deleted
Symbol/Icon in List for TV Free, TV scramble, Radio Free, Radio Scamble, Other Free, Other Scrambled
Import of NEUTRINO + NEUTRINO BOUQETS(channeltree), normal ascii file with delimited ";" ASCII
Saving under DVB, SATCO, NEUTRINO, NEUTRINO BOUQETS(channeltree), normal ascii file with delimited ";"
EXTRAS:
ChannelNameTable.txt full filling of "empty channels" and "NoName" for ASTRA/HOTBIRD
building new channel list and channel tree for ASTRA/HOTBIRD
Thank YOU very much, HAVE YOU EVER RED A MANUAL? ME NOT :)
I never used a manual because most softawre are intuitively! But always there remain some small questions.
However Thank you very much for your help.
But concerning 2) after selecting many channels or all channel the fields are read only no changes can be done!
____________________________________________
1.) after import in a new list -> you have to change the device infos for all channels -> multiple select and then modify your device infos
2.) after insert a sdx file -> you can select all channels which you want (very easy) -> and then change the lnb as you want - and then click "modify"
3.) Progdvb get your deviceinfos on which card is active - and which card make the scans and which one is in use.
i would not read the dvb-hardware from your pc, and i think, this is not necc., because you can hold this from progdvb.
on my ss1 dvb card it is:
SUBID=16 TYPE=2 DLLID=skysr1tt
IT IS LESS WORK - if you have read the manual from ProgEdit
"multiple select" + click the label of the field which you want to change - then the field is active and the programm will change all sected channels to the value of the "active fields"
PS: the channel list is emtpy, because your device infos are not included in the channel list, which you have generated with the import of sdx files.
the NEW other questions -> i will answer on the new forum2.
sorry for your extra work
cu camel
____________________________________________________
Ok thank you very much for this very usefull tool...
But i still have problems using it!
when i import an *.sdx file into an empty channel list the new channels are displayed in ProgEdit but the channel list in ProgDVB still empty . Strangely ProgDVB displays the number of channel in channel list --> global statistic.
My second question: is it possible to make the program asking me "to which Diseqc 1-4 do you want to import the *.sdx file" and let him include to all imported channels the choosed value.
And my last question: from where do ProgDVB get the information about my device infos? Is it possible to let ProgEdit get this infos like progdvb and include it for all channels. It is a very hard work to do it manually for over 1000 channels.
Thank you very much again and happy new year :)
Re: Thank YOU very much, HAVE YOU EVER RED A MANUAL? ME NOT
hi @ all
platingladiator wrote:I never used a manual because most softawre are intuitively! But always there remain some small questions.
well - you only have to read my comments .....
After you select more than 1 channels all fields are "read only" - better words -> "not active" -> _>>> NOW CLICK ON THE LABEL OF THE WANTED FIELD WHAT YOU WANT TO CHANGE -> THEN IT WILL "BE AVTIVE" and now you can change the value as you want.
PLS: the value of the activated fields will be set for selected channels.
ALL "NOT ACTIVATED FIELDS" will not be changed for qall channels.
so you can easy select the fields what you want to use for all channels
clear ? - or please RTFM -> "Read The - I AM AN IDIOT - Manual" and search for "multiple select"
cu camel
PLS: new version will be out on night.
Update!
Ohhh the problem doesn´t existe any more in the version ProgEdit_1.111
Thank you
NEIN NEIN NEIN, it doesn´t work ...
You can believe me i´ve followed your "Anweisungen"
I can activate all labels but only the one for device-infos is wrong, please try it.
Excuse me to disturb you again,
after importing channels from *.sdx i still have no picture.
I´ve followed your instructions to change all 4 LNB positions using multiple select, press the label, make the change and then modify.
I´ve also changed my device info (i´ve the same as you! 16 - 2 - skysr1tt) .
The problem is that in channel propery inside progdvb i find other values for the LNB position as i inserted using ProgEdit!!!! e.g. Value 5 instead of 4!!!!
And the other problem is that Progedit doesn´t import PMT values and i can´t insert those values manually because they are different for each channel.
Thank you and sorry again :)
platingladiator wrote:Excuse me to disturb you again,
LNB positions - you have to change like in ProgDVB - i have only minidiseqc (2 lnb's) and i can't test you system.
i had test to import the *.sdx files and on my system the pmt are also imported. without PMT you won't get a picture - this is true :)
1.) can you check the import with PMT once again ?
2.) can you send me the sdx file , that i can check this once again ?
3.) can you try my sdx file which is included (in dir "extra") and let me know how it works ?
cu camel
history:
ProgEdit - ProgDVB Channel Editor v.1.112 02.01.2007
+ new functions -> for default values in ProgEdit.ini
+ new functions -> for COMANND LINE options
+ new functions -> for "FREE DEFINE EXPORT IN ASCII TEXT FILE" for all fields and sort order as you want
+ new functions -> automatical reading channel list + tree on startup
!! for info about how to use this special features - see the ProgEdit.ini file !!
!! i worth to tkae some min utes time Smile !!
if i send every day a new version -> Prog will get soon a heart attack Smile
this before i will upload on dvbcube this version.
cu camel
http://www.zshare.net/download/progedit_1-112-rar.html
http://www.dvbcube.org/index.php?action ... attach=394
Hello camel :)
thank u very much for this new features, it works great :)
Just one thing: "Start_ExitAfterCommandLine=1" seems to work randomly...
i'm going to try this deeply and i'll give u my feedback
thks again :)
olixelle wrote:Hello camel :)
thks again :)
this will only work if:
If Start_CommandLineModus > 0 And Start_CommandExport > 0 And Start_ExitAfterCommandLine > 0 Then
Application.Exit()
End If
cu camel.
PS: new version 1.113 is ready in 10 minutes
camel wrote: this will only work if:
Application.Exit()
End If
i know u told this in ini file but it didnt work every time until i change columns selection....
#15
Application.Exit()
End If
??? what do you mean ????
can you produce this error once again ?
so - i wait with upload the new version.
