oNe3 wrote:ideas
Will be fine to localize program on other languages (I can help translate on russian)
upgrade multisort mechanism to view what columns is sorted and make him many universal
turn of save dialog if files saved manually
add auto remember for last opened files
add filters for fields. its great thing in case you have many than 1000 channels
my bugs
my crazy interface sight nothing changed
all other programs based on .NET all fine!!!
after exiting editor, program still in memory and load CPU on 100%
Screenshot of interface
Thanks!!!
well the bug - you're the first which a heard , that it doesn't work correctly.
i be sure, that it will work on a fresh install. i think, somewhere your system is not perfect installed. you can try to uninstall all the stuff from MS net 1.1, 2.0, 3.0 - then reboot and try the progedit once again. then it should not work
then you nmcan be sure, that it is not anymore on your system.
then try to install the net 1.1 , try progedit - install net 2.0 try it once again, then MS .net 3.0 and try once again ...
let me know if this helps.
for the other stuff - well thanks good ideas.
1.) other language support. maybe i think about to make a external acsii file, where everybody can help to make the translation.
so - maybe you want to beginn - the list.
simple ascii file
and so is the structure:
(1. line)
English;Deutsch;Italian;Russian;
Menue; Menü; .....
you must only write the words/letters/messages here inside and i will do the rest.
";" is the seperator
about the filter a have told - that you can so easy to handle with sorting as you want, that i think,., it is not really necc. ok the list is longer - but the multisort works really good, that you can handle then this without forget channels if you click all channels and want to change something on it.
alöso the multiselect works fine and so you can sort before your listwith multiple click on the head of columns (ascend + descend) and then select as you want.
but ok - if "some" other guys want also that stuff - then i will do it.
or ?
multisort - i had also talk about - this is implemented.
well - amultisort does no other stuff like that :
if you want to sort col1, col3, col5, col2 (asc or desc - however) (like excel) -> it does not other stuff as : sort the list for col2, then col5, then col3, then col1. do you have understand ?
you have only to click on the columns in backward row, then you have it sorted in multi-sort+ordered as you wanted.
it would be very easy to make a extra windows, whre you can select which columns you want to sort - but it goes easier if you click the columns what you want - or ?
so try it - and you will be happy
cu camel
thanks for your ideas and will - and is every time is welcome to help to make the tool better:)
