Hallo !
I´ve made an installation of ProgDVB 6.51.02 on my Windows XP Notebook and everything worked well.
Yesterday I´ve made the same installation on my Windows Home Server. The installation was o.K. and there were no errors.
The Problem is, that I have no picture
Level and Quality of the DVB-T Signal is o.K.
This is the Error-Message: "Pin for connection not found. Stream type MPEG2. Probably one of nescessary codecs is not choosen or not installed on your computer"
I´ve received the same message for MPEG-Audio
If I check up Settings => Options => Video and Audio and chose the ELECARD MPEG2 Decoder the problem is still not fixed because I receive the same errormessage and the screen is still black
Perhaps there is some problem with installation ProgDVB on Windows Home Server ??
Best regrads
Frank
Re: Problem after installation of ProgDVB on Windows Home Se
#3Where can I get an other video codec ?Prog wrote:Try use other video codec
#4One more idea, change Video render to VMR7 for example.
#5O.K.
I will try this
So you think, this is no generally problem with the installation on windows home server ?
I will try this
#6I hope no. Also you can install last directx _9_ and last .net
#8Scrap that the latest update seems to have fixed it
