Since a few versions ago I have the following problems with VMR7 and VMR9:
a) VMR7 – there is no refresh of the tv image after a window was placed in front of ProgDVB and the removed. Here are the steps to check this:
1. Set as videorender VMR7.
2. While the ProgDVB window is not on full screen mode open another program (Firefox or Internet explorer).
3. The opened program will be in front of the ProgDVB.
4. Minimize the opened program,
Result: There is no tv image in ProgDVB, instead parts of the minimized program are visible.
PS: this also happens when opening ProgDVB menus or the Option window,
The TV preview returns when resizing the ProgDVB window or going to full screen mode.
b) VMR9 – this works well until opening the Options wndow. Here are the steps to reproduce this:
1. Set as videorender VMR9.
2. Open the Options window of ProgDVB.
3. Do not make any change and close the Options window by pressing Cancel.
4. Press the pause button to enter timeshift pause mode.
5. While the ProgDVB window is not on full screen mode open another program (Firefox or Internet explorer).
6. The open program opens in front of the ProgDVB.
7. Minimize the opened program,
Result: There is no tv image in ProgDVB (instead parts of the minimized program are visible).
Note: After pressing again the pause button the tv preview returns.
Does anyone have this problems on XP SP3?
VMR7 and VMR9 refresh problems
#1| WinXP SP3 or Win10 1709 | i5 660@3.33Ghz | 4 Gb RAM | ATI Radeon HD 5450 1Gb|
| Prog demux |
| Prog demux |
