Error on buffer in memory (solved by limitation of size)
I updated from some 6.4x Version to 6.49.8 and then 6.51.7. In both versions, all of a sudden, I'm having this error, when Time Shift Buffer is set to Memory. If I set it to disk, it is working.
When the message box pops up, Time Shift is disabled, but TV program is running.
It worked before -> update (over-install) -> does not work anymore. Only additional thing that has changed is, that I included the Media Server(home) during install. But even if I disable it in the Modul setup, the error stays.
Can someone help me out? I could try, downgrading again and/or deleting the Media Server, but I'd like to solve the problem on this version, if possible.
Re: Error on buffer in memory
What size have you set for the timeshift buffer? I have this message if I set it over 600 MB due to x32 memory limitation. Any value under 600 MB works fine.
| Prog demux |
The last versions of ProgDVB use seem to be using more memory for this reason the timeshift buffer decreased.
Shaker1978 can you help me with a bug that I have on XP? Is my problem described in this post: viewtopic.php?f=2&t=5940 reproducible on your system too?
| Prog demux |
Is this question for me?
| Prog demux |
